How to realize the requirements of site attendance data, monitoring return and telecommuting through Aweseed?
With the in-depth advancement of smart site construction, modern construction scenarios put forward higher requirements for information systems. It is necessary to meet real-time management needs, but also to ensure operational safety, and to achieve efficient collaboration. All of this is inseparable from stability. Reliable network support.
Picture alt
How can the site network be deployed quickly and at low cost to realize real-time remote transmission of data?
For example, the on-site access control system is closely integrated with the face recognition attendance system to ensure that the laid-off records of personnel are accurate. Through a stable network connection, they realize real-time synchronization of data to the headquarters personnel system to ensure the integrity and timeliness of attendance data.
At the same time, the construction site needs to interface with the headquarters ERP and engineering management system, so that engineers can obtain timely design changes, material instructions and progress feedback. More importantly, in order to realize site safety supervision and accident warning, the high-definition monitoring system must return the real-time picture to the headquarters.
However, in the real environment of a construction site, network deployment is often extremely challenging.
● Most construction sites are remote or complex in terrain, lack of basic network facilities, difficult to cover fiber or broadband in time, high construction costs and long cycles, and difficult to meet flexible deployment needs.
Due to the short cycle and frequent layout changes in many construction sites, traditional network solutions are often unable to adapt to the rhythm of rapid deployment and transition, resulting in high network deployment costs and reconstruction costs.
● The construction site environment is often extremely harsh, and the equipment is easily affected by high temperature, high humidity, dust, vibration, etc., and common network hardware cannot be applied.
Flexible, cost-effective, Aweseed bring smart site networking solutions
In order to deal with the problems of complex site environment, remote location, difficult to follow up network infrastructure, and frequent transitions leading to infeasibility of traditional solutions, Aweseed has created a smart site remote networking solution specially designed for construction sites based on SD‑WAN technology developed independently.
Picture alt
The solution has the ability to provide one-stop network access and data secure remote transmission, as well as low deployment threshold, flexible networking and remote operation and maintenance capabilities. Compared with traditional network solutions, Aweseed can effectively save costs, improve efficiency, and help enterprises enhance their competitiveness in the industry.
Aweseed Advantage 1:R300 Series Solves Problems of Access to Site Attendance Terminal and Video Surveillance Equipment
Aweseed can provide R300 series of industrial off-site networking routers with built-in 4G/5G access capability. It can provide reliable network access for site attendance terminals and high-definition video monitoring equipment without relying on optical fiber or wired broadband. With the intelligent master/standby network mechanism, the series supports automatic switching between wireless and wired, dual-card or multi-link, significantly improving network continuity and anti-interference ability.
Picture alt
Facing the challenges of uneven coverage and large signal fluctuation of operators in remote construction site environment, R300 series also supports the Aweseed of three-way card, which allows a single card to automatically switch to the operator with the best network quality among China Mobile, China Unicom and China Telecom, thus ensuring the stability of connection.
In addition, the R300 series equipment itself is industrial-grade design, equipped with sheet metal housing, rail mounting method, and has good protective performance, suitable for dust, extreme temperature or vibration environment of the site deployment. At the same time, R300 series also integrates rich industrial interfaces (such as serial port RS-232/485, DI/DO, etc.), which can be directly and seamlessly connected with industrial equipment on site such as PLC and sensors, simplifying the system integration process.
It is worth mentioning that the Aweseed R300 series has won the recognition of many smart construction sites and users from all walks of life by virtue of its leading technical strength. The market performance is very outstanding. In 2024, the market sales of online e-commerce platforms for Aweseed remote networking routers The share is the first in China.
Aweseed Advantage 2: Self-developed SD-WAN Technology to Solve Site Networking and Data Return Problems
Different from the traditional virtual private network scheme, Aweseed uses the self-developed SD‑WAN technology to quickly build a virtual local area network in any complex network environment. Without relying on dedicated line or public network IP, it can realize real-time remote transmission of site attendance system, high-definition video monitoring and project data, and safely access the headquarters ERP or project management system, thus efficiently supporting intelligent site management.
Picture alt
Further, in the construction area with network fluctuation and weak signal coverage, the Aweseed can also use the self-developed weak network optimization mechanism to maximize the data patency of unstable links through algorithms such as automatic error correction, delay suppression and intelligent packet retransmission.
In addition, Aweseed global intelligent routing capabilities, the best path can be dynamically selected between multiple operators based on real-time network quality. Whether it is cross-regional construction management or overseas construction projects, it can ensure smooth on-site video monitoring and timely attendance data at the same time.
Aweseed Advantage 3: Cloud deployment, operation and maintenance to meet the needs of flexible site relocation
Aweseed support cloud-based unified configuration and off-site networking capabilities, making the construction site network deployment and operation and maintenance to achieve "zero contact". More importantly, this approach is highly compatible with the site characteristics of short construction cycles and frequent site changes. Whether it is the opening of a new construction site or the relocation and adjustment of the project, the project site only needs to connect the R300 series routers with electricity, and the cloud platform can remotely complete the remote networking configuration and instantly complete the construction of the remote virtual local area network, which not only greatly improves the deployment efficiency, but also significantly reduces the labor cost.
Picture alt
At the same time, through the Aweseed cloud visual management platform, IT managers can uniformly issue configurations across projects and locations, monitor network status, push firmware updates, and even automatically respond to fault alarms. The whole process does not require on-site intervention, thus greatly improving the operation and maintenance response speed and flexibility.
Summary: With the deepening of the construction of smart sites, modern construction sites gradually put forward higher requirements for information systems. Based on self-developed SD-WAN technology, Aweseed provides a set of low deployment cost, no dedicated line, high availability of off-site networking solutions for the site, significantly improving the efficiency of deployment and operation and maintenance, while reducing personnel and construction costs. Starting from the network, the Aweseed plan provides a solid foundation for the "real-time, safe and efficient" operation of the smart construction site, and also provides a strong support for the contractor to win the competitive advantage.
